Simply visit here: http://nicedit.com/download.php(http://nicedit.com/download.php)
Select "nicUpload" from the optional nicEdit plugins, then extract the file nicEdit.js into scp/js this will overwrite the version from osTicket, supplying the upload button! (Images will be hosted by imgur, not your server)
To make it work for your server not imgur, read here:
http://stackoverflow.com/questions/12697664/nicedit-picture-upload-to-own-server-doesnt-work-configuration-wrong(http://stackoverflow.com/questions/12697664/nicedit-picture-upload-to-own-server-doesnt-work-configuration-wrong)
Then here:
http://stackoverflow.com/questions/12662062/nicedit-upload-images-locally-fails(http://stackoverflow.com/questions/12662062/nicedit-upload-images-locally-fails)
Download that guys files, edit scp.js to include your uploadURI, then faff some more, then remember you need to create the upload directory (mine is kb/images), set the URI (in nicUpload.php, you did (download nicUpload.php) right?), I used a hard-coded value.. this is so when the script completes it creates an <img src=URI+imageID />
element..
I changed nicUpload.js:
var nicUploadButton = nicEditorAdvancedButton.extend({
nicURI : 'http://yourserver.tld/kb/nicUpload.php',
and nicEdit.js:
/* END CONFIG */
nicURI : 'http://intranet.tdj.com.au/support/kb/nicUpload.php',
Took a bit, but I got it working, only mod to osTicket code was the inclusion of the uploadURI bit in scp.js: (seriously, a comma and uploadURI: 'http://yourserver.tld/kb/nicUpload.php')
/* NicEdit richtext init */
var rtes = $('.richtext');
var rtes_count = rtes.length;
for (i = 0; i < rtes_count; i++) {
var initial_value = rtes.value;
rtes.id = 'rte-' + i;
new nicEditor({
iconsPath: 'images/nicEditorIcons.gif',
}).panelInstance('rte-' + i);
if (initial_value == '') {
nicEditors.findEditor('rte-' + i).setContent('');
If that was confusing, its because I need food.. but rest-assured, if you stare at it hard enough, the button will appear, then you can delete the stupid "Image Shack" mod if you are using his code:
if(this.uri == this.nicURI) {
myDoc.write('<div style="position: absolute; margin-left: 160px;"><img src="http://imageshack.us/img/imageshack.png" width="30" style="float: left;" /><div style="float: left; margin-left: 5px; font-size: 10px;">Hosted by<br /><a href="http://www.imageshack.us/" target="_blank">ImageShack</a></div></div>');
Because, well, you aren't.. so having that there is wrong.
