I upgraded to 1.7.1 just now. The /scp site is working fine however the front-end user site is not.
The relative links are not being formed correctly. See below
They should not contain ".OST/upload/".
Any ideas? The site is running under Windows/IIS
I manually set line 68 of main.inc.php
define('ROOT_PATH', '/support/');
Looks to be an issue with, probably just on IIS i'd guess.
$here = substr(realpath(dirname(__file__)),
strlen($_SERVER));
Hard coding the ROOT_PATH broke logging into the scp site.
I had to go back to the 1.7 method.
if(!defined('ROOT_PATH')) define('ROOT_PATH','./'); //root path. Damn directories//
Check out the github post at:
https://github.com/osTicket/osTicket-1.7/pull/697(https://github.com/osTicket/osTicket-1.7/pull/697)
Is this the front end page issue that you are getting? (See attached file).
This is the only issue that I am experiencing after upgrading from 1.7 to 1.7.1
Not sure how to overcome this problem.
Thanks in advance for any help.
AK
