italian set
I'm italian, and I use character as è à ò: ho can I add this set
@setlocale(LC_TIME, 'it_IT');
Thanks
  • and when customer post a reply into his ticket, after click on post reply-->show a blank page!
  • Posting replay on this incase others are looking for the answer!
    You should change the settings to use strftime..
    In class.format.php change the function to:
    function date($format,$gmtimestamp,$offset=0,$daylight=false){
    setlocale(LC_ALL, 'sv_SE');
    if(!$gmtimestamp || !is_numeric($gmtimestamp)) return "";
    $offset+=$daylight?date('I',$gmtimestamp):0; //Daylight savings crap.
    return strftime($format,($gmtimestamp+($offset*3600)));
    Set locale to your own and then in settings change the date and time format to according for exempel (more info se php manual for strftime):
    Time Format: %k:%M
    Date Format: %Y/%m/%d
    Date & Time Format: %Y %m/%d %k:%M
    Day, Date & Time Format: %A %e %B %Y klockan %k:%M
  • TACK Claes!!
    I've been looking for this for ages.
    :D
  • Hi again,
    I'm having problems with å ä ö. (example Måndag)
    It shows as m�ndag.
    Do you know how to fix this? It appears on viewticket and I have the php pages in UTF-8.
    Thanks
    Robert
  • Sorry missed one thing..
    Use this..
    setlocale(LC_ALL, 'sv_SE.UTF-8');
  • Thank you so much, you're the man!
    Works like a charm.
