Support Ticket System Offline
I get this error message after succesfully running the installation.
Does anyone have any idea? I have a feeling that its probably a mysql problem
I created a database called osticket and a username with full privileges to os ticket.
The installer said everything was ok.
But i get this error when attempting to browse it for the first time.
Support Ticket System Offline... :(
  • found answer
    I found the answer.
    Apperently its turned off to begin with.
    FYI for anyone
    look under //scp/admin.php
    log on as admin and click on the admin panel (TOP RIGHT) and make osticket available to everyone.
    GOOD SO FAR!!!!
  • th350urc3;641 said:
    I found the answer.
    FYI for anyone
    GOOD SO FAR!!!!
    Searching would have saved you time :)
    http://www.osticket.com/forums/showthread.php?t=145
    Someone had the same problem. ;)
    But I must say that I think it's not a bad idea to make it online by default instead of offline.
