Hi All:
I installed OSTicket a few months back, and it's been working just fine until this morning. Now, every page is blank. the support/scp/login.php page is blank, the /support/index.php page is blank, every page is just blank. When I 'get page source' for the pages, there is no code there. Not sure what's up. I've tested PHP, and it's still installed. I've been able to mock-up new pages, put them in the directories, and view them no problem (both simple html, and php).
To see what's up, you can try to go to http://www.papernysites.com/support(http://www.papernysites.com/support) Nothing shows up.
Any suggestions? Help? Advice? I've trolled through the forums and seen a few instances of people with similar problems, but none of the suggested solutions have helped me. I'm at the point where I'm thinking I may just re-install OS-ticket and try again, but I'm curious if anyone might know what's going on.
Thanks
Mark M. Pinder
