Osticket emailing help
i got it all setup but when i open a ticket it says it has sent it too [email]jim2557@hotmail.com[/email] with the ticket id but i never get the email and im using my isp email server host for it i have no idea whats wrong with it id pay someone 30$ if they could fix it i need some help on this.
  • Have you tried a simple mail script to make sure that the php mail() function is working?
    test.php
    PHP Code:
    PHP Code:
    <?php
    if(mail(\"recipient@abc.com\",\"subject\",\"body\",\"From: [email]from@abc.com[/email]\"))
    echo \"email sent\";
    else
    echo \"email failed\";
    Upload it to your server and open up the file through a browser. What happens?
  • this is what i get when goin to test.php
    Warning: mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\AC Web Ultimate Repack\Server\htdocs\test.php on line 2
    email failed
  • Do you have access to your php.ini file?
  • yes i do have access to my php_ini file
  • in php.ini theres a mail section. you need to setup the smtp and smtp_port in there. Make sure you restart after you set it.
