Hello,
I'm new to osTicket. I have installed osTicket and configured it. It was about 10 days since i installed it. But, yesterday I received 6 mails reporting SQL Error. The mails read as
- You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '2) OR ticket.staff_id=4) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '2) OR ticket.staff_id=4) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1) OR ticket.staff_id=5) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1) OR ticket.staff_id=5) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1) OR ticket.staff_id=5) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1) OR ticket.staff_id=5) AND status='Open' AND (ticket.staff_id=0 OR ticket.staf' at line 1Please help me eliminate these errors.
Thanks in advance,
R. Kaja Mohideen
