I uploaded the upload folder to a wamp server, and I can get to the installer screen, I enter all of my information, then when I click install, it just refreshes the page and the text boxes fill back up with the default content. Anyone know what seems to be going on?
What does the default content look like?
<?=$name?>
If it looks like that, you need to turn short_tags on
Hi all,
Yes i have same issue using wamp, my short tags are switched on too.
Installed it to my localhost first which uses xampp and it installed no problems.
Is there an issue with wamp??
Problem Installing help
Did you tried to reupload all files again? If no, try to do it. You can also try to upload all files to the different directory and install it again. Then you will see where the problem is.
