Admin- Authentication Required
Hi, i had the same problem when i was supposed to log in, i was told that i need to log in after using the registeret username and password.
I dont know why this happend to me but it solved my problem, what i did was to try to comment out the two lines in mysql.php
if($$dblink) {
// @[deleted]('SET NAMES "UTF8"');
// @[deleted]('SET COLLATION_CONNECTION=utf8_general_ci');
This did not help and i thougt that setting short_open_tag = on in php.ini could have affected my installation, what i tried was to set this parameter to off but then i got the message that this page could not be viewed.
When i changed back this parameter to on i was able to log on to my site.
I guess that this is not the solution for this problem but it helped me in this cenario.
