Using RC4, and when putting a URL with an & in it, it is breaking.
http://www.someurl.com/page.php?item=blah&item2=blah2
When you insert that link, it converts the &'s to & then it tries to convert it to a linkable URL, causing the link to be:
<a href="http://www.someurl.com/page.php?item=blah&">http://www.someurl.com/page.php?item=blah&</a>;item2=blah2
When searching for a solution to this issue, I came across an issue that was supposedly fixed in RC3 that could be relevant. The above URL was on a line by itself, so the fix that was implemented may be causing this new issue. Issue I mentioned is:
http://osticket.com/forums/project.php?issueid=18(http://osticket.com/forums/project.php?issueid=18)
