There is an updated ajax.js file that will stop IE from crashing when you try to load the staff panel, although I am still unable to access it.
save the below as "ajax.js" and upload it to your /scp/js folder on your webserver.
Peter
Simple httprequest wrapper. It will be replaced by an ajax framework in the future.
Based on Wrapper by http://adamv.com/dev/javascript/http_request
var Http = {
ReadyState: {
Uninitialized: 0,
Loading: 1,
Loaded,
Interactive,
Complete: 4
Status: {
OK: 200,
Created: 201,
Accepted: 202,
NoContent: 204,
BadRequest: 400,
Forbidden: 403,
NotFound: 404,
Gone: 410,
ServerError: 500
Method: {Get: "GET", Post: "POST"},
enabled: false,
req: null,
Init: function(){
if (window.XMLHttpRequest) {
Http.req = new XMLHttpRequest();
else if (window.ActiveXObject) {
Http.req = new ActiveXObject("Microsoft.XMLHTTP");
Http.enabled = (Http.req != null);
get: function(params, callback_args){
if (!Http.enabled) throw "Http: XmlHttpRequest not available.";
var url = params.url;
if (!url) throw "Http: A URL must be specified";
var method = params.method || Http.Method.Get;
var callback = params.callback;
// Only one request at a time, please
if ((Http.req.readyState != Http.ReadyState.Uninitialized) &&
(Http.req.readyState != Http.ReadyState.Complete)){
this.req.abort();
Http.req.open(method, url, true);
Http.req.onreadystatechange = function() {
if (Http.req.readyState != Http.ReadyState.Complete) return;
if (callback_args == null) callback_args = new Array();
var cb_params = new Array();
cb_params.push(Http.req);
for(var i=0;i<callback_args.length;i++)
cb_params.push(callback_args);
callback.apply(null, cb_params);
Http.req.send(params.body || null);
Http.Init();
