setting up crontab
i have a plesk server with debian linux installed on it.
i also have root access.
i need to install a crontab to fetch my pop mail. how exatly do i do it?
crontab */2 * * * * /var/www/vhosts/domain.com/httpdocs/support/api/cron.php
  • [LIST=1]
    [*]login as "root" using SSH (probably putty)
    [*]type in the command "crontab -e"
    [*]an editor opens
    [*]add the line "*/2 * * * * /path/to/php/executeable /path/to/api/cron.php" at the bottom
    (on my server it's "*/2 * * * * php5-cgi /home/www/web1/html/ticketsupport/api/cron.php")
    [*]end editor (the way how to close depends on your server and installed editor)
    [*]server prints out sth. like "installing new cronjob"
    [*]DONE
    [/LIST]
  • when i wrote "which php"
    i answered me: "/usr/bin/php"
    so i wrote my crontab like this:
    */2 * * * * /usr/bin/php /var/www/vhosts/domain.com/httpdocs/support/api/cron.php
    Enable Auto Cron: ON
    Mail Methods:
    Enable POP3 email fetch: ON
    Enable email piping: OFF (should this be on?)
    On the edit email:
    POP3 Status: Enable
  • if "/usr/bin/php" is the executeable itself fine.
    but maybe it's just the dir of PHP ?
    anyway : did it work or not ?
    if not : run "/usr/bin/php /var/www/vhosts/dittnett.com/httpdocs/support/api/cron.php"
    from commandline and post what it says
  • when i run it nothing happens...
    just another line...
    so i can write a new command
    i have these php folders:
    php
    php-cgi
    php-config5
    php5
    phpextdist
    phpize5
    phpunit
  • i got it to work i just tried all! :)
    but i get this report in the SSH:
    server:/usr/bin# /usr/bin/php-cgi /var/www/vhosts/domain.com/httpdocs/support/api/cron.php
    PHP Notice: Undefined index: SCRIPT_NAME in /var/www/vhosts/domain.com/httpdocs/support/main.inc.php on line 19
    PHP Notice: Undefined index: SCRIPT_NAME in /var/www/vhosts/domain.com/httpdocs/support/config.php on line 20
    PHP Notice: Undefined index: SCRIPT_NAME in /var/www/vhosts/domain.com/httpdocs/support/main.inc.php on line 79
    PHP Notice: Undefined index: REMOTE_ADDR in /var/www/vhosts/domain.com/httpdocs/support/main.inc.php on line 97
    PHP Notice: Undefined variable: dblink in /var/www/vhosts/domain.com/httpdocs/support/include/mysql.php on line 28
    PHP Notice: Undefined variable: prefix in /var/www/vhosts/domain.com/httpdocs/support/include/class.pop3.php on line 147
    PHP Notice: Undefined index: phone in /var/www/vhosts/domain.com/httpdocs/support/include/class.validator.php on line 54
    PHP Notice: Undefined index: attachment in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 842
    PHP Notice: Undefined index: deptId in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 880
    PHP Notice: Undefined index: source in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 882
    PHP Notice: Undefined index: deptId in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 892
    PHP Notice: Undefined index: ip in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 908
    PHP Notice: Undefined index: REMOTE_ADDR in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 908
    PHP Notice: Undefined index: phone in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 919
    PHP Notice: Undefined index: REMOTE_ADDR in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 461
    PHP Notice: Undefined index: attachment in /var/www/vhosts/domain.com/httpdocs/support/include/class.ticket.php on line 940
    X-Powered-By: PHP/5.2.0-8+etch7
    Set-Cookie: PHPSESSID=0u27atda5j49bclq0cfhk9c9d3; path=/
    Expires: Thu, 19 Nov 1981 08:52:00 GMT
    Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
    Pragma: no-cache
    Content-type: text/html
    changed my domain with domain.com
  • OK, I had this same problem, and fixed it earlier, but forgot what I had done to fix it. Had so go back to the original and compare.
    Here is the corrected 'api/cron.php':
    <?php
    cron.php
    File to handle cron job calls (local and remote).
    Peter Rotich <peter@osticket.com>
    Copyright (c) 2006,2007,2008 osTicket
    http://www.osticket.com
    See LICENSE.TXT for details.
    $Id: $
    require_once('../main.inc.php');
    require_once(INCLUDE_DIR.'class.dept.php');
    require('api.inc.php');
    require_once(INCLUDE_DIR.'class.cron.php');
    Cron::POP3(); //pop3 mail fetch
    Cron::Tickets(); //Tickets related crons.
    Vs
    Original:
    <?php
    cron.php
    $Id: $
