hello there,
PHP version: 5.2.6
MySQL version: 5.0.45
osTicket version: RC4
I am trying to install osTicket but getting the following error message on installation /setup/index.php
Invalid SQL schema. Get help from Developers
You have an error in your SQL syntax CREATE TABLE ost_k
Can anyone suggest a solution?
Thanks in advance!
