After upgrading to 1.9.2 the "print ticket" feature returns a 500 - Internal server error. There is a problem with the resource you are looking for, and it cannot be displayed.
Any ideas?
PHP Version 5.4.3System Windows NT INTRANET 6.0 build 6002 (Windows Server 2008 Standard Edition Service Pack 2) AMD64 Build Date May 15 2012 02 Compiler MSVC9 (Visual C++ 2008) Architecture x64 Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--without-dblib" "--without-pdo-dblib" "--without-pdo-mssql" "--with-pdo-oci=C:\php-sdk\php54dev\vc9\x64\deps\instantclient_10_2\sdk,shared" "--with-oci8=C:\php-sdk\php54dev\vc9\x64\deps\instantclient_10_2\sdk,shared" "--with-oci8-11g=C:\php-sdk\php54dev\vc9\x64\deps\instantclient_11_2\sdk,shared" "--disable-debug-pack" "--disable-static-analyze" "--disable-zts" Server API CGI/FastCGI Virtual Directory Support disabled Configuration File (php.ini) Path C:\Windows Loaded Configuration File C:\php\php.ini Scan this dir for additional .ini files (none) Additional .ini files parsed (none) PHP API 20100412 PHP Extension 20100525 Zend Extension 220100525 Zend Extension Build API220100525,NTS,VC9 PHP Extension Build API20100525,NTS,VC9 Debug Build no Thread Safety disabled Zend Signal Handling disabled Zend Memory Manager enabled Zend Multibyte Support provided by mbstring IPv6 Support enabled DTrace Support disabled Registered PHP Streamsphp, file, glob, data, http, ftp, zip, compress.zlib, pharRegistered Stream Socket Transportstcp, udpRegistered Stream Filtersconvert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.*
