Hi, I did a clean installation of 1.9.4 but when I run the page of the user, I receive many emails Error #1054. I do not understand where I have the problem. The 1.9.3 I have never had problems. Solutions?Thank!!!
Error attach file
Versione osTicket:
v1.9.4-rc1 (509e2f2)
Software Server
Apache
Versione PHP
5.3.28
Versione MySQL
5.5.28
Try a php update - I know that someone else also had problems, maybe different problems, but after a PHP Update everthing worked fine again. For example my osTicket installation is running with PHP 5.5 and I did not have any trouble with 1.9.4-RC.
Hi Chefkeks, thanks for your message.In my local server I have php 5.5.3 and 5.5.35 SQL but I have the same problem. I solved disabling the alert email for problems DB.
As a reminder this is a Release Candidate and should not be used in a production environment. You should make sure that you report issues like this on github.
