hola buenos días, resulta que tengo un problema y necesito ultilizar osTicket pero el software está en Inglés, necesito saber si una conversión del problema es posible o si hay una versión en español.
Espero su respuesta lo antes posible y me insta
hello good morning, I happen to have a problem and I need ultilizar osTicket but the software is in English, I need to know if a conversion of the problem is possible or if there is a version in Spanish.
There is no official Spanish version at this time.However once 1.9.4 is released we will be a lot closer to a translatable version with language packs that you will be able to install.
I wanted to know one thing , I have installed the 1.7.0 version of osTicket in Spanish . is possible that the tickets creeen users reach me now all my email
There is no such thing as a Spanish version of osTicket. If you installed one you got it from somewhere else, and not us. If you are having a problem with your installation you should upgrade to a more recent version, and not use a custom version that you got from some place else. We only provide support for versions that we release. So you would want to talk to whomever you got your Spanish copy from.
