RichEdit - toolbar not appear
Today I had a case when it does not appear RichEdit Toolbar.
It was at customer office on a single computer with Windows XP and InternetExplorer 8 .....
What determines in this case, the possibility to use the Toolbar.
  • Rich text editor we use doesn't support IE 8. We're on the tail end of dropping IE 8 support.
  • The rich text editor is Redactor.  Which is a .js provided by http://imperavi.com/redactor/
    So I would say the ability to execute javascript.
  • Thanks for the info.
    I have another question whether the configuration of osTicket only this option:
    "Ticket Settings and Options / Enable HTML Ticket Thread"
    is responsible for activating the RichEdit Toolbar?
    and
    Is this function may be dependent on the specific server environment in which osTicket  is installed ?
  • Yes, Admin panel -> Settings -> Tickets -> Enable HTML Ticket Thread toggles if the Rich HTML editor is utilized.
  • Is that normal when user which want to post ticket without login but only via website portal, can not change color for text ?
