Remove required comment during department transfer
Is it at all possible (I don't mind editing code) to remove the need to compulsorily comment on a ticket when assigning or department transferring?  I'm filtering all emailed tickets manually to the correct departments. It really doesn't need to be commented upon.
It'll save me tapping in 5 random characters.
  • /scp/tickets.php
    line 162 - 168
    you could set $_POST['assign_comments'] to be something static.
    You could change the code here to not check if its empty.
    You could change the 5 to a 0.
  • Thanks.. Maybe consider adding a checkbox somewhere in the admin panel to allow these comments to be required or optional?
