Hi everyone, I love osTicket system :). I use cloud based Office365 and I want to use it with osTicket. I set-up the following credentials; E-mail: example@example.com IMAP+SSLoutlook.office365.comIMAP Port - 993POP3 Port - 995Encryption - SSLSMTP Serversmtp.office365.comPort - 587Authentication Required - YesBut I get this error message: IMAP does not exist. PHP must be compiled with IMAP active.Has anyone the same problem like me? Is there an solution to fix this problem? Thanks in advance! Sincerly,Bas
PHP on your webserver doesn't have IMAP enabled.How to fix that varies a little by host OS.In linux you can install the php5-imap package.Debian/Ubuntu command line: apt-get install php5-imapIn Windows you can simply edit the php.ini and add or uncomment: extension=php_imap.dllnote: you also need to make sure that this file is in your extension_dir.
Hi ntozier, Thanks for your quick message and the clear information about my problem! I dont know the problem, until now :-). I'm gonna to fix this right now. Hope it works :-) Again, many thanks for your help!
Very welcome.Please post a follow up as to if this resolved your issue (It should resolve that issue, but you may encounter another once you fix that).
