I initially installed OSTicket on host with PHP 5.6 and everything was terrific.I switched to PHP 7 and when I open up my installation, I get a 500 internal server error.Are there any known issues with PHP 7?
PHP 7 is not (yet) supported!
Q: Are there any known issues with PHP 7?A: yes. osTicket does not support PHP7 at this time. Once 1.10 is released I believe that it will however. If not 1.10 then the version after that,
Hello,Do you have a date for the PHP7 compatibility?
Q: Do you have a date for the PHP7 compatibility?A: When 1.10 is released. It's release date is: When it is ready.
Osticket PHP 7.1 or higher support. Looking back - it looks like the last comment was back in April 2016. How likely will this happen in 2017?
@[deleted] How likely will what happen?PHP 7 is supported now (but some people have reported issues).PHP 7.1 is not supported at this time and there are known incompatibilities.
My webserver running PHP 7.0.18-0ubuntu0.17.04.1 seems to work great with 1.10
