i have looked up many of the other forums and i could not find a fix for my issue on them.
We have the domain from godaddy and i was able to upload all the fills just fine, the problem that we are having is that when we go to fill out all the info and install it it says "Unable to connect to MySQL server. Possibly invalid login info". i have check the login for it a dozen times and everything seems to be right. we have the MySQL database thru godaddy would that be an issue?
Make sure you're using the correct hostname.
MySQL Table Prefix, MySQL Hostname, MySQL Database, MySQL Username, MySQL Password. triple check they are all correct. still giving same error
When you say "triple check" - do you mean you can manually login via command line or MySQL admin tool?
If I'm I'm not mistaken, I believe godaddy uses different hostname for web connections.
Via MySQL admin tools. myself and the systems administator here checked it and we keep getting the same thing.
Check with godaddy or see http://support.godaddy.com/help/article/39/locating-your-databases-host-name(http://support.godaddy.com/help/article/39/locating-your-databases-host-name)
@[deleted]
I'm with Go Daddy and came across your post.
Were you able to connect to your database?
If you are still unable to connect, please feel free to reply or private message me. I would like to assist you further.
Dear Ken_GoDaddy,
You make me smile.
