Hallo,here is the situation. I am sure it could help someone with the same problem, especially those who are not so skilled on php.1. Tried to un-phar the file (it.phar taken from https://osticket.it/) to a zip one using this online tool:http://pmt.mcpe.me/pocketmine.phpIt gave me internal file error.2 I downloaded the phar file from your packages list in your official site (http://osticket.com/download-edge).3. Tried to un-phar once again and it worked. No error!4. Got the file in zip format and used the related .yaml file to modify the translation. Finally I zipped it.5. Then I used the same online tool to re-create the phar file from zip. Very important: pay attention. Before converting to phar remember to add a file called plugin.yaml otherwise it will not work. Here is howto create it: http://wiki.bukkit.org/Plugin_YAMLNOW: the front-end ita translation works very fine. Unfortunately the Admin Pannel has now lost the translation and everything is back to English !All file in /i18n/ seem to be right. Please, what's going on? Any advice about howto to cope with it? Thank you!
