hey, corn not work. It does not work after upgrading from v1.9.15Information about my osticket:When i try run from shellroot@web:/var/www/https/helpdesk/osticket# php api/cron.phpPHP Warning: Declaration of AssignmentForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in /var/www/https/helpdesk/osticket/include/class.forms.php on line 4150PHP Stack trace:PHP 1. {main}() /var/www/https/helpdesk/osticket/api/cron.phpPHP 2. require() /var/www/https/helpdesk/osticket/api/cron.phpPHP 3. require_once() /var/www/https/helpdesk/osticket/api/api.inc.phpPHP 4. Bootstrap:() /var/www/https/helpdesk/osticket/main.inc.phpPHP 5. require() /var/www/https/helpdesk/osticket/bootstrap.phpPHP 6. require_once() /var/www/https/helpdesk/osticket/include/class.user.phpPHP Warning: Declaration of TransferForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in /var/www/https/helpdesk/osticket/include/class.forms.php on line 4270PHP Stack trace:PHP 1. {main}() /var/www/https/helpdesk/osticket/api/cron.phpPHP 2. require() /var/www/https/helpdesk/osticket/api/cron.phpPHP 3. require_once() /var/www/https/helpdesk/osticket/api/api.inc.phpPHP 4. Bootstrap:() /var/www/https/helpdesk/osticket/main.inc.phpPHP 5. require() /var/www/https/helpdesk/osticket/bootstrap.phpPHP 6. require_once() /var/www/https/helpdesk/osticket/include/class.user.phpPHP Fatal error: Uncaught Error: Call to undefined function mysqli_init() in /var/www/https/helpdesk/osticket/include/mysqli.phpStack trace:#0 /var/www/https/helpdesk/osticket/bootstrap.php(182): db_connect('localhost....', 'osticket', 'passsss...', Array)#1 /var/www/https/helpdesk/osticket/main.inc.php(28): Bootstrap:()#2 /var/www/https/helpdesk/osticket/api/api.inc.php(23): require_once('/var/www/https/...')#3 /var/www/https/helpdesk/osticket/api/cron.php(17): require('/var/www/https/...')#4 {main}thrown in /var/www/https/helpdesk/osticket/include/mysqli.php on line 28When i try run php5.6root@web:/var/www/https/helpdesk/osticket# php5.6 api/cron.php<b>Fatal Error:</b> Contact system administrator.Any idea what is wrong?
