Ok, just to give you some update about this matter.The only way that I could find to rename the folder was the option proposed by ntozier.I use a text editor that supports project management. Create a project with all the site files and made a search all over the files looking for the string 'scp'. The result, 74 files modified in some part of the code, and 2 files renamed (scp.css and scp.js).I don't really like this workaround because I'm pretty sure that in upcoming updates I will be facing issues updating. So, with the help of the 2mhost support team, we are looking for some solution to fix the problem. I'll keep you posted.Regards.
