From /var/log/httpd/error.log Apache/2.2.15 (Unix) DAV/2 PHP/7.0.14 configured -- resuming normal operations PHP Warning: Declaration of AssignmentForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in /var/www/html/include/class.forms.php on line 4150, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP Stack trace:, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 1. {main}() /var/www/html/scp/system.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 2. require() /var/www/html/scp/system.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 3. require_once() /var/www/html/scp/admin.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 4. require_once() /var/www/html/scp/staff.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 5. Bootstrap:() /var/www/html/main.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 6. require() /var/www/html/bootstrap.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 7. require_once() /var/www/html/include/class.user.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP Warning: Declaration of TransferForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in /var/www/html/include/class.forms.php on line 4270, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP Stack trace:, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 1. {main}() /var/www/html/scp/system.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 2. require() /var/www/html/scp/system.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 3. require_once() /var/www/html/scp/admin.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 4. require_once() /var/www/html/scp/staff.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 5. Bootstrap:() /var/www/html/main.inc.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 6. require() /var/www/html/bootstrap.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.php PHP 7. require_once() /var/www/html/include/class.user.php, referer: http://ticketsys.osfulab.tbe.com/scp/settings.phpzend_mm_heap corruptedzend_mm_heap corruptedzend_mm_heap corruptedzend_mm_heap corrupted
