Hi I've a problem with interface of our clients.If they search anything inside search box, the result of post action is that nothing happen... :-(I've upgraded to 1.10 from 1.9.12 just 2 days ago and in rel 1.9.12 all works fine.Thanks
Here you can see server info
Try searching with out the prefix?My guess would be that like most search engines including something like -STRING would result in telling the search engine to not match on that pattern (in this case string).
I have tried to search for string, for ticket label, but nothing.If i try to search from SCP, all works fine, the problem is only if i try to search from client view
I believe this is an issue across 1.10
I have this issue too,in client page, search function doest work with any string or text.
There are a number of search related issue reports on github have you searched them for a solution to your issue?
Hi ntozier,sorry but on github i don't find any solution on search on client side.Can you link them?Thanks
If you do not find an issue report for your issue then you should open one.
