On a fresh install of osTicket v 1.10 I am receiving a "Valid CSRF token required" error when trying to log in to the admin panel at "http://localhost/scp/login.php". After jumping into the code at "/scp/login.php" and changing "if (!$ost->checkCSRFToken())" to "if ($ost->checkCSRFToken())" it skips the error but instead I get sent back to the login screen with the message "authentication required".I am running osTicket as a test environment on the latest version of Xampp on Windows 7 running Apache 2.4.25, MariaDB 10.1.21, PHP 7.1.1, phpMyAdmin 4.6.5.2. I also installed all the extra packages except for the Zend OPCache Extension.The php error log is empty, this is the Apache error log: PHP Warning: Declaration of AssignmentForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in C:\\xampp\\htdocs\\include\\class.forms.php on line 4150, referer: http://localhost/scp/login.php PHP Warning: Declaration of TransferForm:($options) should be compatible with Form:($staff = true, $title = false, $options = Array) in C:\\xampp\\htdocs\\include\\class.forms.php on line 4270, referer: http://localhost/scp/login.php PHP Warning: session_start(): Failed to read session data: user (path: C:\\xampp\\tmp) in C:\\xampp\\htdocs\\include\\class.ostsession.php on line 86, referer: http://localhost/scp/login.php
