I have upgraded to v1.10 but now i can't login because the ldap plugin has been overwritten. All my users are set to ldap so i need to know the defualt value for a staff member that doesn't have ldap set. Any ideas?
Upgrading osTicket does not in fact update your LDAP plugin. It certainly doe snot change your settings or overwrite anything. Perhaps you should update your LDAP plugin.
Turns out i did the update wrong. In answer to my own question the default value for backend in ost_staff is 'local'
Local there would mean that your staff can only use the local (osTicket) authentication ... not LDAP. :)If you want to set it to either it should be blank.
