What does it mean?It means that the form sent to you by the server has a token with it. When you logged in and sent the details back the token did not match the one that the server thinks it sent you.How do I fix it?There are a number of things that could be happening. There could be a bunch of tokens for you and they need to be cleared. Your browser cache could need clearing. There could be another problem (systemic) that is causing the issue. There is no simple answer. However I bet if you clear your cache and consult your PHP error logs and osTicket error logs and webserver (not provided) error logs maybe there will be a better hint at why it's happening.
