First you will need a SSL Certificate for the server you are using, and then you will just change the URL for Helpdesk URL within OST and add s after http. Unforutnately it's been a very long time since I have dealt with certificates, so I am not 100% sure how to install them properly. If you have a third party host then inquire with them. Otherwise maybe someone with more knowledge can chime in.
