Is it possible to connect osticket with G Suite for login?
Your question is to vague to answer.If you mean can osTicket auth to gsuite accounts and collect emails to make tickets then the answer is yes.If you mean can osTicket authenticate users or agents using gsuite then I dont think so. But there is an unreleased oauth plugin at the repo you might be able to use.https://github.com/osTicket/osTicket-plugins/tree/develop/auth-oauth
Is it possible to integrate G-Suite to osTicket in a sense that all emails sent and received through gmail is ticketed?
Thank you. -AOS.
All emails sent to a speficic email address sure. You would configure osTicket to check that email address.
Hi ntozier, Thank you for your reply. May i ask, Is the integration between osTicket and gmail utilizing the push notification? Instead of the periodic checking of the mailbox?
-AOS.
I would presume that it simply checks the email account every couple minutes depending on how you configure it.
Anyone has any idea if public can sponsor for features to be developed and if any rates mentioned?
I think that they can, but I know that they are in the middle of a couple large projects right now and probably cannot take on more. You can reach out to them at https://osticket.com/contact-us/
Thank yo ntozier, i think i will do that.
Very welcome.
