Hi Guys,I was new new OSticket, just installed v 1.10 in my Ubuntu 16.04 using this linkhttps://www.howtoforge.com/tutorial/how-to-install-osticket-with-nginx-on-ubuntu-16-04/But, I encountered white blank popped up on screen once I add New Ticket and Set password to user account. Please see attached screenshot.Here's my configserver { listen 80; server_name osticket.hakase-labs.com; root /var/www/osticket/upload; access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log; index index.php; client_max_body_size 2000M; client_body_buffer_size 100M; client_header_buffer_size 10M; large_client_header_buffers 2 10M; client_body_timeout 12; client_header_timeout 12; keepalive_timeout 15; send_timeout 10; gzip on; gzip_comp_level 2; gzip_min_length 1000; gzip_proxied expired no-cache no-store private auth; gzip_types text/plain application/x-javascript text/xml text/css application/xml; set $path_info ""; location ~ /include { deny all; return 403; } if ($request_uri ~ "^/api(+)") { set $path_info $1; } location ~ ^/api/(?|tasks).*$ { try_files $uri $uri/ /api/http.php?$query_string; } if ($request_uri ~ "^/scp/.*\.php(+)") { set $path_info $1; } location ~ ^/scp/ajax.php/.*$ { try_files $uri $uri/ /scp/ajax.php?$query_string; } location / { try_files $uri $uri/ index.php; } location ~ \.php$ { fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; include fastcgi_params; include snippets/fastcgi-php.conf; fastcgi_pass unix:/run/php/php7.0-fpm.sock; fastcgi_param PATH_INFO $path_info; }}
