Hi ThereI having an issue with layout after install to my server.1. tool tip has blank or not read able,, the pop up only blank after change some ting on the system or post replay2. i tried to reinstall and add ht access for mime type and still facing same issueHere the detail information on it:About this osTicket Installation
Server Information
osTicket Version
v1.10.1 (9ae093d)
— Up to date
Web Server Software
Apache
MySQL Version
5.6.38
PHP Version
5.6.36
PHP Extensions
gdlib
Used for image manipulation and PDF printing
imap
Used for email fetching
xml
XML API
xml-dom
Used for HTML email processing
json
Improves performance creating and processing JSON
mbstring
Highly recommended for non western european language content
phar
Highly recommended for plugins and language packs
intl
fileinfo
Used to detect file types for uploads
APCu
Improves overall performance
Zend Opcache
PHP Settings
cgi.fix_pathinfo
"1" is recommended if AJAX is not working
date.timezone
UTC
