I've setup osTicket version v1.10.1 on a server with PHP 7.0.Per the documentation in manage.php I've imported organizations and users but there appears to be a few issues with the user class in this set of scripts.Attempting to activate a user with this command:php manage.php user -U {user_id} -v activate -mResults in the following error:PHP Fatal error: Uncaught Error: Call to undefined method UserAccount:() in /var/www/html/include/cli/modules/user.phpStack trace:#0 /var/www/html/include/class.cli.php(240): UserManager->run(Array, Array)#1 /var/www/html/manage.php(74): Module->_run('user')#2 /var/www/html/include/class.cli.php(240): Manager->run(Array, Array)#3 /var/www/html/manage.php(83): Module->_run('manage.php', false)#4 {main} thrown in /var/www/html/include/cli/modules/user.php on line 98With a bit of digging I was able to confirm that create doesn't seem to exist for this class.Here's the activate section of the switch statement in include/cli/modules/user.php case 'activate': $users = $this->getQuerySet($options); foreach ($users as $U) { if ($options) { $this->stderr->write(sprintf( "Activating %s <%s>\n", $U->getName(), $U->getDefaultEmail() )); } if (!($account = $U->getAccount())) { $account = UserAccount:(array('user' => $U)); $U->account = $account; $U->save(); } if ($options) { global $ost, $cfg; $ost = osTicket:(); $cfg = $ost->getConfig(); if (($error = $account->sendConfirmEmail()) && $error !== true) { $this->warn(sprintf('%s: Unable to send email: %s', $U->getDefaultEmail(), $error->getMessage() )); } } } break;I did some digging and discovered that line 98 should probably be calling UserAccount: rather than UserAccount:, but the attempts that I've made to resolve have a bit of a rabbit hole of what appears to possibly be ghosts left behind by retooled classes. I'm hoping someone here has potentially ran into this before. In the meantime I'm going to continue to work out a solution.One additional note, there also appears to be an issue with this same class. Any search by email address returns every user, not just the ones that match the search criteria.
