I think that you are best suited to answer your own question.
If you are competent in PHP and feel comfortable doing so then by all meas you should give it a try.
If you are not competent in PHP or do not feel comfortable attempting to perform the mods then you probably should not.
They will not be able to be implemented by following the instructions because most of the files that your supposed to update have changed. In some cases the changes are a little, and in some cases a lot.
