Hello..
I'm Using CentOs on vmware that is connected to the Internet, I have httpd installed and running.. I successfully installed osticket, however I'm having trouble connecting through imap - pop and I'm having these Errors..
Invalid login. Check IMAP settings
Can't connect to gmail-imap.l.google.com,993: Permission denied
I am really sure the username and password are correct..
These are the Imap settings:
Host : imap.gmail.com
Port : 993
SSL : Enabled / Or Disabled (Tried both options) however I need it to be Enabled for google, So Left it On.
Tried smtp.google.com ports: 465, 587
What Im suspecting is either something missing in centos installations / bad ssl configuration / port blocked...
I Decided to write this after I became hopeless..
any Advices are really appreciated!
