Upgrade from 1.6 to 1.7 didn't work, so I'm trying a clean install.
Created new database with collation UTF8_unicode_ci
Uploaded all files. Go to install page, checks ok. Rename ost-config.php
Enter user and database info... Continue... then get error
Error parsing SQL schema! Get help from developers (#4)
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1'', `ipaddr` varchar(64) NOT NULL, `apikey` varchar(255) NOT NULL, `can_c' at line 3
Setup
Linux CentOS cpsrvd 11.34.1.14
MySQL 5.5.23
MySQL charset: UTF-8 Unicode (utf8)
PHP 5
Hosted on Hostgator
