Here is the inside of my ost-config.php
<?php
ost-config.php
Static osTicket configuration file. Mainly useful for mysql login info.
Created during installation process and shouldn't change even on upgrades.
Peter Rotich
Copyright (c) 2006-2010 osTicket
http://www.osticket.com(http://www.osticket.com)
See LICENSE.TXT for details.
$Id: $
#Disable direct access.
if(!strcasecmp(basename($_SERVER),basename(__FILE__)) || !defined('ROOT_PATH')) die('kwaheri rafiki!');
#Install flag
define('OSTINSTALLED',TRUE);
if(OSTINSTALLED!=TRUE){
if(!file_exists(ROOT_PATH.'setup/install.php')) die('Error: Contact system admin.'); //Something is really wrong!
//Invoke the installer.
header('Location: '.ROOT_PATH.'setup/install.php');
exit;
# Encrypt/Decrypt secret key - randomly generated during installation.
define('SECRET_SALT','REMOVED-BY-MODERATOR');
#Default admin email. Used only on db connection issues and related alerts.
define('ADMIN_EMAIL','support.website@REMOVED-BY-MODERATOR');
#Mysql Login info
define('DBTYPE','mysql');
define('DBHOST','localhost');
define('DBNAME','REMOVED-BY-MODERATOR');
define('DBUSER','REMOVED-BY-MODERATOR');
define('DBPASS',REMOVED-BY-MODERATOR');
#Table prefix
define('TABLE_PREFIX','ost_');
